SOLVED O365 Install with Visio or Project but only if previously installed
Jeneration Me
I know I'm probably missing this but I need to create an O365 installer and have it install Visio or Project only if it was previously installed. Is there a good way in the config.xml file to do this?
I have some neither Visio or Project, some with Visio, some with Project and some with both.
:-) I was hoping to avoid that.
I'm thinking it can also be done with a task sequence, but eh....
This can be closed. Thank you for your input.
If you deployed Visio or Project with SCCM you could use "Supersedence " to upgrade the previous versions.
Works great on my end
