PENDING No Management Point shown Task Sequence Media
rhinotechie
I'm using ConfigMgr 1910 and I know in the past that I have created a few bootable medias and can't remember what version it was working in and have updated a few times since then and just noticed yesterday when trying to create a bootable media that there was no MP showing up. I have attached a screenshot and if anyone has experienced this issue it would be greatly appreciated to share your resolve.
Cause: You will run into this issue if the Management Point is configured to use HTTPS and you are using the self-signed certificate and not importing the PKI certificate while creating the TS bootable media.
Resolution:
To fix this you will need to import the certificate on the Security page.
Certificate requirements:
  • Certificate Purpose: Client authentication
  • Template to use: Workstation Authentication
NOTE This certificate must be exported in a Public Key Certificate Standard (PKCS #12) format, and the password must be known so that it can be imported.
