SOLVED Need help with SCCM Query list all devices
Marcel Motto
I need a query which lists all devices based on device properties variables type "thin".
Can someone help me?
if you are looking to create a collection based on that value then it impossible or almost impossible to do this. if you are looking for reporting query this would be much easier to do. but still not easy. what exactly are you trying to do with this info?
those are custom variables that you set in your client settings to do inventory based on the hardware classes. if you can find the classes, you should be able to find the WQL query.
otherwise, have a look if they all have the same chassis type then you can create the collection based on that
link
Thanks for this info, I can not use chassis type unfortunately. Some devices are installed under the wrong chassis type , for testing.
and what are you going to do with this info? do you need a collect or report?
I want to create a collection, my problem is that I have laptops in a test environment (QAS) and in a productive environment (PROD). I need a collection for each. At the moment I solve this with AD groups query. AD groups query is not my preferred solution
I don't think that you can do this in WQL. if it is possible you will have to write a custom query, but I don't even know where you would find this value in WQL.
JorgeRM
