nhughes122
Good afternoon, I'm reaching out to this awesome forum for some help solving an issue that we're having with a newly create task sequence that works for one of our domains and not for the other.
Domains
We have a single TS called "Company Deployment" that uses the User Driven Interface app (UDI) to allow the user to select some information like which domain and OU to join as well as what applications. They IT folks are PXE booting to their local DP and all using the same boot image to run this TS.
The issue is that is a user in a boundary of COMPANYX.net PXE boots to their local DP, gets the correct boot image, selects all the correct information to image (the companyx.net domain and their computers OU) and during the image, we see a number of errors and the image never joins the domain or installs the COALESCEDAPPS array of applications.
Also, I did notice in my current task sequence (right) I do not have a set domain account and password steps like I see on an older task sequence (left). Is this part of the UDI that is required or is the final network settings step at the bottom the definitive place to add the domain credentials?
Any help is greatly appreciated!
Domains
- na.COMPANYR.local
- COMPANYX.net
- Additional Information
- From inside the na.companyr.local domain, I am able to run the same TS with the same information and the image TS is successful and joins to the domain and installs the applications properly.
- The credentials we're using na/SVC_USER1 are trusted across both domains
- I have validated the content on that DP
- The errors we're seeing in smsts.log are Failed to Connect to Management Point and Failed to find property 'AutoApplyDeployment'
