Hi
I have setup azure services and import MS Store apps on to SCCM.
After I create new application from "License Information for Store Apps" and deploy "Whiteboard" apps.
On client PC I can see MS Store Apps "Whiteboard" I select install and is not installing.
I had a look in AppEnforce.log file, I've copyed the log and pasted here for you to see : -
+++ Starting Install enforcement for App DT "WindowsStoreBSPDeeplinkDT_Microsoft Whiteboard - Windows app package (in the Windows Store)" ApplicationDeliveryType - ScopeId_C656CC97-A162-423F-9162-F2D729B9C165/DeploymentType_7e8f57e4-f94b-4e8a-b356-085121873af2, Revision - 1, ContentPath - , Execution Context - User AppEnforce 08/08/2019 10:26:40 8372 (0x20B4)
The content path is not specified for DeploymentType ScopeId_C656CC97-A162-423F-9162-F2D729B9C165/DeploymentType_7e8f57e4-f94b-4e8a-b356-085121873af2. Content is assumed to be locally available. AppEnforce 08/08/2019 10:26:40 8372 (0x20B4)
A user is logged on to the system. AppEnforce 08/08/2019 10:26:40 8372 (0x20B4)
Installation failure, error code = 0x80190194 and error message is 'Not found (404).
' AppEnforce 08/08/2019 10:26:41 8372 (0x20B4)
+++ Enforce completed for ScopeId_C656CC97-A162-423F-9162-F2D729B9C165/DeploymentType_7e8f57e4-f94b-4e8a-b356-085121873af2, 1 using Package: Microsoft.Whiteboard____8wekyb3d8bbwe. Returning: 80190194 AppEnforce 08/08/2019 10:26:41 8372 (0x20B4)
+++ AppX Install Info added. [AppDT Id: ScopeId_C656CC97-A162-423F-9162-F2D729B9C165/DeploymentType_7e8f57e4-f94b-4e8a-b356-085121873af2] AppEnforce 08/08/2019 10:26:41 8372 (0x20B4)
++++++ App enforcement completed (0 seconds) for App DT "WindowsStoreBSPDeeplinkDT_Microsoft Whiteboard - Windows app package (in the Windows Store)" [ScopeId_C656CC97-A162-423F-9162-F2D729B9C165/DeploymentType_7e8f57e4-f94b-4e8a-b356-085121873af2], Revision: 1, User SID: S-1-5-21-3991474764-66990301-30549166-5982] ++++++ AppEnforce 08/08/2019 10:26:41 8372 (0x20B4)
Seem that I got error "Installation failure, error code = 0x80190194 and error message is 'Not found (404)."
I couldn't find to able to solve this, so I try this forum if you have any ideas how to fix this?
Many thanks
Rachel
Many thanks
Rachel
