SOLVED Management point seems to be stuck
  • Thread starter Thread starter jgo
jgo
Hi Guys,
I'm running SCCM 2012 R2 SP1 since a few years, to install OS automatically or push some application packages.
Now I decided to use the Software Update feature to help me pathing our network with the Windows security updates.
I installed WSUS on my primary site and I configure it to synchronize with SCCM and everything works fine.
I also created a test package successfully and tried to deploy it to a client machine. As my client didn't recieve any package I began to troubleshoot my client side.
When I check the locationservices.log I saw a few strange errors, and I found that my MP didn't work correctly.
Can somebody help me on that issue or help me to understand these logs?
Thanks Guys,
Javier
Ok, I found the solution, my clients communicated with the Site to a bad port, I had to push a reinstallation of the sccm client and everything works again.
