PENDING Management Point Installation - Pre Req CCMSetup. Return Code 6
  • Thread starter Thread starter callananc
  • Views Views 4K
callananc
I have been try to install a management point on our new primary server but it is erroring with the below:
<04/19/21 11:05:14> ====================================================================
<04/19/21 11:05:14> SMSMP Setup Started....
<04/19/21 11:05:14> Parameters: D:\Program Files\Microsoft Configuration Manager\bin\x64\rolesetup.exe /install /siteserver:SRVW0182 SMSMP 0
<04/19/21 11:05:14> Installing Pre Reqs for SMSMP
<04/19/21 11:05:14> ======== Installing Pre Reqs for Role SMSMP ========
<04/19/21 11:05:14> Found 2 Pre Reqs for Role SMSMP
<04/19/21 11:05:14> Pre Req CcmSetup found.
<04/19/21 11:05:14> Installing pre-req using command line "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp
<04/19/21 11:06:47> Pre-req installer "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp finished with exit code 6
<04/19/21 11:06:47> Failed to Install Pre Req CcmSetup. Return Code is 6
<04/19/21 11:06:47> This was a required Pre Req, can not continue.
<04/19/21 11:06:47> Installation Failed. Error Code: 6
<04/19/21 11:06:47> ~RoleSetup().
<04/19/21 11:06:54> ====================================================================
<04/19/21 11:06:54> SMSMP Setup Started....
<04/19/21 11:06:54> Parameters: D:\Program Files\Microsoft Configuration Manager\bin\x64\rolesetup.exe /install /siteserver:SRVW0182 SMSMP 0
<04/19/21 11:06:54> Installing Pre Reqs for SMSMP
<04/19/21 11:06:54> ======== Installing Pre Reqs for Role SMSMP ========
<04/19/21 11:06:54> Found 2 Pre Reqs for Role SMSMP
<04/19/21 11:06:54> Pre Req CcmSetup found.
<04/19/21 11:06:54> Installing pre-req using command line "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp
<04/19/21 11:08:18> Pre-req installer "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp finished with exit code 6
<04/19/21 11:08:18> Failed to Install Pre Req CcmSetup. Return Code is 6
<04/19/21 11:08:18> This was a required Pre Req, can not continue.
<04/19/21 11:08:18> Installation Failed. Error Code: 6
<04/19/21 11:08:18> ~RoleSetup().
<04/19/21 11:08:56> ====================================================================
<04/19/21 11:08:56> SMSMP Setup Started....
<04/19/21 11:08:56> Parameters: D:\Program Files\Microsoft Configuration Manager\bin\x64\rolesetup.exe /install /siteserver:SRVW0182 SMSMP 0
<04/19/21 11:08:56> Installing Pre Reqs for SMSMP
<04/19/21 11:08:56> ======== Installing Pre Reqs for Role SMSMP ========
<04/19/21 11:08:56> Found 2 Pre Reqs for Role SMSMP
<04/19/21 11:08:56> Pre Req CcmSetup found.
<04/19/21 11:08:56> Installing pre-req using command line "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp
<04/19/21 11:10:21> Pre-req installer "D:\Program Files\Microsoft Configuration Manager\CMUClient\ccmsetup.exe" /UpgradeWithServer:mp finished with exit code 6
<04/19/21 11:10:21> Failed to Install Pre Req CcmSetup. Return Code is 6
<04/19/21 11:10:21> This was a required Pre Req, can not continue.
<04/19/21 11:10:21> Installation Failed. Error Code: 6
<04/19/21 11:10:21> ~RoleSetup().
I used the Config Manager PreReq tools to install the managment point pre-reqs and I have tried removing the role and re-adding the role but I'm still having the above issues.
Any ideas what could be causing it?
There is no version of the ccm client installed.
Craig
Craig
I know this is an old thread. Did you ever resolve the issue?
I am facing this right after an upgrade.
Thanks,
Joe
dimasyandr
