SOLVED Manage office365 updates using SCCM
Krishna Yadav
Active Member
Please help me with the update management procedure for office 365 using sccm 2012 SP1.
Can we manage update deployment using old mechanism ( i.e. like we manage to update workstations by creating of SUG of update catalogs and deploy on the collection) in SCCM 2012 ?
Regards,
You are trying to manage office 365 updates using a older version of sccm. I suggest you to upgrade to atleast Configuration Manager version 1606 so that you can use the Configuration Manager client setting to manage the Office 365 client agent.
Thank you very much for the reply..
I am not in the situation to upgrade SCCM 2012 to CB due to some licensing roadblock.
Is it not possible to manage update for Office 365 with SCCM 2012 ? If yes please give some hint to take forword.
Appricate your responces.
Yes, let me know if this video helps.
Thank you very much .. really helpful vedio.
Could you please help is the below query..
Is there any way to deploy office 365 by detecting system as per workstation local language and install with single package using SCCM 2012 also uninstall all existing MS offices.?
Appricate your support.
