Ben Radlinski
Long time, first time. I had a perfectly healthy SCCM environment, running on 2K12 R2, CM 1706, but then I decided I was going to roll out SSL so I could begin managing mobile devices. Unfortunately I got a little ahead of myself and turned everything on before setting up any PKI in our environment. So now all of my clients are cut off from the SCCM server because they're unable to get a certificate.
I went back into the configuration to remove my changes and did the following:
-Removed the MP System Role and reinstalled it with HTTP.
-Removed the DP System Role and reinstalled it with HTTP.
The clients are still not able to contact the server. I'm not sure what logs I should look at on the client side in order to troubleshoot this issue.
Any help would be appreciated.
