NEW Issues installing SCCM Client on WorkGroup Device via Task Sequence
  • Thread starter Thread starter AdamK
  • Replies Replies 4
  • Views Views 9K
AdamK
Hello
I've successfully manually install the SCCM Client to a Workgroup device using the following command from the command line within Windows 10.
ccmsetup.exe /mp:SCCMSERVER.domain.co.uk SMSSITECODE=123 SMSMP=SCCMSERVER.domain.co.u DNSSUFFIX=domain.co.uk
I can see the device hostname appear and I can approve it on my Management Server under devices without any issues.
I want to automate this as part of a Task Sequence, therefore within my Task Sequence I've edited the "Setup Windows and Configuration Manager" step and added the following Installation Properties:
ccmsetup.exe /mp:SCCMSERVER.domain.co.uk SMSMP=SCCMSERVER.domain.co.u DNSSUFFIX=domain.co.uk
However the devices are appearing as UNKNOWN in the under Assets and Compliance\Devices. I can tell it's the new machine as the MAC Address is listed under the summary.
I've also tried just adding
I cannot use the SMSSITECODE option within the installation propertiesas it's not allowed.
Any advice is greatly appreciated.
Adam
If you approve the computer with the console does it work?
Hi Gareth
Thanks for taking the time to reply.
The devices hostnames are appearing as Unknown and all options seem to be greyed out when the client is pushed from the task sequence, using the above installation properties. Therefore I cannot approve the device.
Where as when I installed the client manually from the command line within Windows with the seitches detsiled above, the hostname appears and the I can approve the device.
Adam
See the attached image that shows the device as unknown and the approval buttons greyed out.
The SCCM Site is blank.
I've just re-tested by settings the following commands in the Installation Properties:
SMSMP=sccm.domain.co.uk /retry:1
But still the new device appears unknown as per the screen shot
What do the install logs say is happen? If you compare a TS install log for the Client vs manually, what is the difference?
dennisv
