SOLVED Installing SCCM 1802 Primary site and selecting its options
  • Thread starter Thread starter syed sameer
  • Replies Replies 6
syed sameer
Hi Prajwal
I am installing new primary site with 1802 version, here I have a question, should I only select following option or should I also select typical installation options as shown below, what if I select typical options ? awaiting your response
1734
If you don't need to make a SCCM hierarchy (CAS, Primary sites...), you need to select "Use typical installation options for a stand-alone primary site" to make this site as stand-alone.
Hi saad
I am installing it as primary and under it we have secondary sites, so in this case does required typical options to select or no need? We have some more primary sites on diffrent domain how should i know whether its standalone primary?
You can install first a stand-alone primary site then you can install the secondary sites.
Each primary site supports up to 250 secondary sites.
