PENDING IBCM cliend update problem
Marek Belan
Hi all
we build IBCM by this video :
app is working fine but client dont sync updates.
On client we have this in log :
wuauhandler:
OnSearchComplete - Failed to end search job. Error = 0x80244007. WUAHandler 5/17/2021 6:49:32 PM 13144 (0x3358)
Scan failed with error = 0x80244007. WUAHandler 5/17/2021 6:49:32 PM 13144 (0x3358)
scanagent.log
ScanJob({29D3E715-9488-46E0-9DF0-7C723C75D302}): CScanJobManager::OnScanComplete- Scan has failed, scan request will be pending for scan retry cycle. ScanAgent 5/17/2021 6:49:32 PM 4700 (0x125C)
CScanAgent::ScanCompleteCallback - failed at OnScanComplete with error=0x87d00631 ScanAgent 5/17/2021 6:49:32 PM 4700 (0x125C)
when i watch to wsyncmgr.log i find this
Indexing Failed. Could not connect to SUSDB. SqlException thrown while connect to SUSDB in Server: vm-ibcm-p01.union.sk. Error Message: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Could not Delete Obselete Updates because ConfigManager could not connect to SUSDB: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server) UpdateServer: vm-ibcm-p01.union.sk SMS_WSUS_SYNC_MANAGER 17.05.2021 18:35:50 43928 (0xAB98)
Sql Exeception was thrown while attempting to delete obselete updates. Error Message: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server) SMS_WSUS_SYNC_MANAGER 17.05.2021 18:36:05 43928 (0xAB98)
IBCM is in DMZ , all ports is OK. Updates was synced, DB is on WID.
But for some reason SCCM cant index and clean updates on IBCM.
So this can by problem some timeout on client scan or something.
Some idea what is wrong ?
Just a quick question, why not cloud management gateway (CMG) ?.
but it looks problem with IBCM WSUS DB. Its on WID and this dons support remote connection. So MECM cant do maintenance task on it. I do it manually and many of client now connect to IBCM.
dimasyandr
