SOLVED HW / SW inventory offline
  • Thread starter Thread starter Manuel
  • Replies Replies 6
Manuel
Hi to all,
Is there any way to get a HW/SW offline inventory?
I would like to get this information locally with the configuration manager agent.
Of course this information has to be readable.
Offline where from server or on the workstation? To do what with info?
From Client, instead of setting locally the information
What you are asking for is not a simple task. at best you can see what was last sent to SCCM but seeing all the data, is not a simple task. So what exactly do you want to do with this info? As maybe there is a better way.
I want to take the inventory offline from a PC that belongs to a domain but have a poor conneciton and carry this information (using USB or something) to the SCCM CB
Any ideas?
