Dear All,
I have some desktops that came with either 1 hard disk or 2 hard disks. And the applications were installed on the Drive D for those desktops with 2 hard disks. Usually, I need to create 2 application tasks, one task will be installed on Drive C and the other task will be installed on Drive D.
It is possible to create 1 application task which suits the below criteria? (take Google Chrome as an example)
The task will check if Chrome was installed on Drive C and thus the installation will install on Drive C.
If Chrome was installed on Drive D then the installation will install on Drive D.
