NEW Help troubleshooting OSD task sequence application installation failed
  • Thread starter Thread starter Ketah
  • Replies Replies 0
Ketah
I am having a problem during OSD deployment. We have created a task sequence, everything is working fine but during installation of application, one application failed to install the problem is I do not experience this when I try to install the same application from the Software Center.
In the SMSTS.LOG (log file zipped and attached) I can find the following error : NotifyProgress received: 16 (Application failed to evaluate )
Again this is a working application from Software Center the issue is only during the task sequence installation during Operating System Deployment.
Could you please help ?
SCCM version : 1902
Kind regards,
CharmedToast
