SOLVED help about wds and group policy
naimat
hi sir how are you hope you are fine i want to deploy windowx xp via wds and i want to restrict usb mass storage for windows xp user on windows 7 policy working but for windows xp user policy not working i am using server 2012 hope when you got time you will reply thanks in advance and i learn alot from you videos and articles with snapshot thanks alot
For windows 7 - Disable USB Mass storage steps
- launch the Local Group Policy Editor:
  1. Click on the Start menu.
  2. In the Search programs and files entry, type GPEDIT.MSC.
  3. In the left field, open Computer Configuration > Administrator Templates > System > Removable Storage Access.
  4. It can show possible option in diologue box whichever you want to disable , you can do it from that option
  5. Double click on the desired setting option and you select the desired option between Not Configured, Enabled and Disabled, the Help column at the bottom right corner displays the details of the option
  6. Select the desired option and click Apply > OK or just OK.
  7. For example if your setting selection is Removable Disk: Deny read access and:
    • Not Configured option is selected (default selection) - allows read access to removable storage disks.
    • Disable option is selected - allows read access to removable storage disks.
    • Enabled option is selected - read access to removable disks is denied.
Windows XP - Disable USB mass Storage Steps
1. Press Save/Recall key.
2. Press Explorer....and navigate to D:\Agilent\Service.
3 Double-click DisableUsbStorage.exe
4. Click OK in the SUCCEEDED message window that appears. If any USB mass storage device is connected to the E5071C under this condition, the Hardware Wizard will start, but the USB mass storage device will not work.
Adding to Maunil's reply, the policies that you have applied to Windows 7 may not work properly with Windows XP. You need to check if the policy is applicable to Windows XP computers. In any case check Group Policy Preference Client Side Extensions for Windows XP. Once you download and install the extensions computer will be able to process the new Group Policy Preference extensions.
thanks i will chek it soon and hope it will help thanks once again and i want to know about wds how to deploy windows xp from wds tommorow i have class about wds i have to teach but still i am worry about this question if someone ask from me how to deploy xp then i dont have answer or solution hope you will reply when you got time thanks alot
Thanks Maunil mehta for windows 7 it work and this policy will work with atleast vista os not for xp i create and apply on windows 7 work but not on xp but i will chek it again as you guide and Prajwal sir and i got templete also i have to try thanks i will ask for help if i got problem again thanks alot
I don't understand why are you still using XP. the support for XP is over. You could start using only windows 7 going forward.
thanks and yes you are right sir but as a instructor i have to answer question and you know student usually ask about xp still and i also got deployment offer where they using xp and 7 both for different users thats why i have to give them solution thanks once again and i want to help people over internet as you are doing sir so tell me how can i post my video here on forum for those who want to learn about mcitp and mcsa in urdu thanks for your time always
joita
