NEW Group by is not working right
  • Thread starter Thread starter Gustavo
Gustavo
Hi there,
I am making a report where I try to show the OU for every computer using MAX function, but for some reason that I still cannot see, the report is returning a register for every CN name. I made a similar report using MAX function and it worked, I got just one register per computer with the full OU name, ej: domain.com/OU1/OU2/OU3. Now I am getting this: register1 --> domain.com/OU1
register2--> domain.com/OU1/OU2
register3--> domain.com/OU1/OU2/OU3
So I am getting 5 or 6 registers per computer.
This is my query, I am sure that I am missing something, but I have not been able to find it:
SELECT DISTINCT
v_R_System.Name0 as "Machine Name",
v_R_System.User_Name0 as "User Name",
v_R_System.User_Domain0 as Domain,
MAX(v_RA_System_SystemOUName.System_OU_Name0) as OU,
CASE WHEN v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0 like '%,%' THEN left(v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0,CHARINDEX(',',v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0)-1)
ELSE IPAddress0 END AS "IP Address",
v_GS_OPERATING_SYSTEM.Caption0 as "OS Name",
v_GS_OPERATING_SYSTEM.CSDVersion0 as "SP Name",
v_GS_OPERATING_SYSTEM.BuildNumber0 as "Build Number",
v_GS_WORKSTATION_STATUS.LastHWScan as "Last Contact",
v_GS_COMPUTER_SYSTEM.Manufacturer0 as Fabricante,
v_GS_COMPUTER_SYSTEM.Model0 as Modelo
FROM
dbo.v_R_System
left JOIN v_GS_OPERATING_SYSTEM ON v_R_System.ResourceID = v_GS_OPERATING_SYSTEM.ResourceID
left join v_GS_NETWORK_ADAPTER_CONFIGURATION ON v_R_System.ResourceID=v_GS_NETWORK_ADAPTER_CONFIGURATION.ResourceID
LEFT Join v_GS_WORKSTATION_STATUS on v_R_System.ResourceID=v_GS_WORKSTATION_STATUS.ResourceID
left join v_GS_COMPUTER_SYSTEM on v_R_System.ResourceID=v_GS_COMPUTER_SYSTEM.ResourceID
left join v_RA_System_SystemOUName on v_R_System.ResourceID=v_RA_System_SystemOUName.ResourceID
WHERE
v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0 not like 'fe%'
and v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0 IS NOT NULL
--and v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0 not like '169.254.%'
and v_GS_NETWORK_ADAPTER_CONFIGURATION.DefaultIPGateway0 IS NOT NULL
and v_GS_NETWORK_ADAPTER_CONFIGURATION.IPEnabled0 = '1'
GROUP BY
v_R_System.Name0,v_R_System.User_Domain0,v_R_System.User_Name0,v_GS_NETWORK_ADAPTER_CONFIGURATION.IPAddress0,v_RA_System_SystemOUName.System_OU_Name0,v_GS_OPERATING_SYSTEM.Caption0,v_GS_OPERATING_SYSTEM.CSDVersion0,v_GS_OPERATING_SYSTEM.BuildNumber0,v_GS_WORKSTATION_STATUS.LastHWScan,v_GS_COMPUTER_SYSTEM.Manufacturer0,v_GS_COMPUTER_SYSTEM.Model0
This is the result of the report
Any suggestion or help would be appreciated
Thanks in advance
Best regards
Gustavo
That is because you have the OU listed within your group by, remove that it and everything will be fine.
