I have a Task sequence which works good. We want to add a step at the start to check the McAfee version. If Version is not equal to 10 Fail the Task sequence.
Is there any way to do that.
the first question would be how would you detect this? once you can answer this question people can guide you to your answer. but clearly this can be done with a script.
Thanks garath, Is there anything in options>Add condition "registry setting", installed software" ,"Query wmi something like that.
I have already created a script but working with conditions
