Please help,,, below is the error in SMS_CLOUD_PROXYCONNECTOR.log
Trying to build Tcp connection c67cc3bf-daae-4d25-913f-13f2891ece21 with server xyz.COM:10140
Starting to connect to Proxy server xtz.COM:443 with client certificate 78547DB5C377EBE140D1CADE632735D319F858C0 and connection ID ca67a1e3-ac15-4697-a0b8-0233b9761353...
ERROR: Failed to build Tcp connection c67cc3bf-daae-4d25-913f-13f2819ece21 with server xxxxx.COM:10140. Exception: System.Net.WebException: TCP CONNECTION: Failed to connect TCP socket with proxy server ---> System.Net.Sockets.SocketException: No such host is known~~ at System.Net.Dns.GetAddrInfo(String name)~~ at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6)~~ at System.Net.Dns.GetHostAddresses(String hostNameOrAddress)~~ at System.Net.Sockets.TcpClient.Connect(String hostname, Int32 port)~~ at Microsoft.ConfigurationManager.CloudConnection.ProxyConnector.TcpConnection.Connect()~~ --- End of inner exception stack trace ---~~ at Microsoft.ConfigurationManager.CloudConnection.ProxyConnector.TcpConnection.Connect()~~ at Microsoft.ConfigurationManager.CloudConnection.ProxyConnector.ConnectionBase.Start()~~ at Microsoft.ConfigurationManager.CloudConnection.ProxyConnector.ConnectionManager.MaintainConnections()
