PENDING Error when installing Dell Integration Suite for System Center
  • Thread starter Thread starter jvasallo
  • Replies Replies 1
jvasallo
When I run the installer Dell-Command-Integration-Suite-for-System-Center_RMCDR_WIN_6.5.0_A00 .exe or DCIS_Setup_6_5_0 .exe I get an error message I haven't been able to diagnose. Here is the log:
[Tue Dec 26 08:48:37 2023] (MUPXMLParser::GetResultName): *** Vendor Return Code is not found in Mup.xml
[Tue Dec 26 08:48:37 2023] Name of Exit Code:
[Tue Dec 26 08:48:37 2023] (DupAPI::GetReturnCode): *** Unable to find DUP value for:
[Tue Dec 26 08:48:37 2023] Execution terminated at date-time Tue Dec 26 08:48:37 2023
[Tue Dec 26 08:48:37 2023] ######
[Tue Dec 26 08:48:40 2023] User Command: attended
[Tue Dec 26 08:48:40 2023] DUP Capabilities Value: 2097151 (0x1FFFFF)
[Tue Dec 26 08:48:40 2023] DUP Vendor Software Version: 6.5.0
[Tue Dec 26 08:48:40 2023] Local System/Model Compatible with this Package? Yes
[Tue Dec 26 08:48:40 2023] Local System OS Version: 10.0.0.0
[Tue Dec 26 08:48:40 2023] OS Compatible with this Package? Unknown
[Tue Dec 26 08:48:40 2023] Local System OS Language: Unknown
[Tue Dec 26 08:48:40 2023] Language Compatible with this Package? Unknown
[Tue Dec 26 08:48:40 2023] User Parameter: logfile
[Tue Dec 26 08:48:40 2023] User Parameter: logfile changed to: C:\ProgramData\Dell\UpdatePackage\Log\Dell-Command-Integration-Suite-for-System-Center_RMCDR_WIN_6.5.0_A00.txt
[Tue Dec 26 08:48:40 2023] Identified Behavior : attended
[Tue Dec 26 08:48:40 2023] Extraction-miniunz path: c:\PROGRA~3\dell\drivers\19F33F~1\miniunz.exe
[Tue Dec 26 08:48:40 2023] Extraction-arguments: -x C:\ADM\DELL-C~1.EXE -o -d c:\PROGRA~3\dell\drivers\19F33F~1
[Tue Dec 26 08:48:40 2023] Extraction-GetExitCode: 0
[Tue Dec 26 08:48:40 2023] Temporary payload log file name: C:\ProgramData\dell\drivers\19f33f12-ca1a-4fc5-bd41-0b46e7c0b545\DUPAC77.tmp
[Tue Dec 26 08:48:40 2023] payloadExe: DCIS_Setup_6_5_0.exe
[Tue Dec 26 08:48:40 2023] payloadArgs: /clone_wait /v"/l*vx \"C:\ProgramData\dell\drivers\19f33f12-ca1a-4fc5-bd41-0b46e7c0b545\DUPAC77.tmp""
[Tue Dec 26 08:48:40 2023] payloadDir: C:\ProgramData\dell\drivers\19f33f12-ca1a-4fc5-bd41-0b46e7c0b545
[Tue Dec 26 08:48:40 2023] MUP Spec version is less than 3 or Not a DCH Package.
[Tue Dec 26 08:48:40 2023] Legacy installation is selected. Calling Vendor Installer...
[Tue Dec 26 08:48:41 2023] Appending Vendor Software Log.
--- Start of Vendor Software Log ---
--- End of Vendor Software Log ---
[Tue Dec 26 08:48:41 2023] Vendor Software Return Code: 3435973836
[Tue Dec 26 08:48:41 2023] logo.png
[Tue Dec 26 08:48:41 2023] (MUPXMLParser::GetResultName): *** Vendor Return Code is not found in Mup.xml
[Tue Dec 26 08:48:41 2023] Name of Exit Code:
[Tue Dec 26 08:48:41 2023] (DupAPI::GetReturnCode): *** Unable to find DUP value for:
[Tue Dec 26 08:48:41 2023] Exit Code set to: 1 (0x1)
[Tue Dec 26 08:48:41 2023] Result: FAILURE
[Tue Dec 26 08:48:42 2023] Open file: C:\ProgramData\Dell\UpdatePackage\Log\Dell-Command-Integration-Suite-for-System-Center_RMCDR_WIN_6.5.0_A00.txt
I haven't come across this error before. May I know the OS on which you're installing this software?. Did you contact Dell support or check Dell forums for this error?
jordysmits
