I created a new test task sequence with the 1809 .wim. I have the 1809 ADK loaded and I am at SCCM 1806. My task sequence is continually failed at applying operating system after the wim is downloaded. The error code is: 0x800004005. I went through the smsts.log and I could not find any obvious errors. My 1803 task sequence works perfectly. This is being deployed to a VM so drivers shouldn't be an issue. I also checked my software distribution account and that is correct also. As it is working with the 1803 image. Any help would be appreciated. Attached is my smsts.log.
