SOLVED Distribution Point GetDPLocations failed with error 0x80072efd
syed sameer
Hi Prajwal
how are you doing ?
i have installed new sccm 1511 , and installed below below site roles on same server machine
1) DP
2)MP
3)SUP
but could not install sccm agent in client machine using client push installation or manual
its give me GetDPLocations failed with error 0x80072efd
0x80072efd - A connection with the server could not be established
i tried to reinstall DP and MP, in log files MP status was success
but DP status says No DMP found
how to solve this issue and also can i install Disribution point on sccm server right ?
Yes you can install the DP role on the SCCM server. We could have checked the log files and done further troubleshooting. But since you have already fixed it, I am marking this thread as Solved.
