PENDING Display driver not installed during Task Sequence
B. Mierzwiak
I have a small problem with drivers :)
When I install my image, everything runs smoothly - then when I log on I can see that the correct Intel Display driver is not installed. Instead the driver is vgapnp.sys
I can manually update it by pointing to my driver folder (where all the drivers for SCCM are saved)
The driver gets installed, I restart and when I check driver info the correct Intel driver is now applied.
Why is this happening? Can I see anything in a log file? Which one?
Thanks Prajwal - yes we did use Auto apply drivers. Someone made a decision not to use driver packages. So I am not sure if that is the solution for us. :) Are there any pros and cons for the 2 methods of applying drivers?
stotfoldchris
