SOLVED Disk space required on Distribution point
Dineshyadav
We are Currently Implementing SCCM 2012R2 SP1 with more than 18K End Points all over. We have Primary Site Server with DP, In the DP It is Drive Space Reserve is 50 MB. In Most of the Forums it is Mentioned to Give Reserve Disk Space is 1000 MB (Sufficient). If we Still Keep the 50 MB as Reserve Disk Space as 50 MB, Does it make any Issue. Please give your valuable Suggestions
Hi Dinesh,
What ever Microsoft has suggested for Disk space, we should have to keep that result only otherwise it will create an issue sometime while implementing SCCM 2012R2 SP1.
So, I would suggest to go for Microsoft defined disk space criteria
Microsoft recommends Drive Space Reserve of 50 MB. You could reserve even 1GB as well.
Marking this thread as Solved.
Pwthel
