PENDING Disassemble and Assembling SCCM Roles in a Productive Secondary Site.
Oscar_Mancera
Hi all, I have a question about this scenary. We have troubles whith a corrupted local Data Base in a Endpoint Manager Secondary Site. This trouble has affected some of System Roles. ¿What happend if disassemble all System Roles in my Secondary Site and then try assembly again all System Roles?
¿Some of this can help me to resolve the DB iIssue and other ones? Some comment about this!
Regards...
My suggestion would be to log a support ticket with Microsoft. Do not modify the ConfigMgr DB as the information stored in DB is always critical.
Ok, got it.
In addition to my first question, the Data Base in our Primary Site is ok, and the DB in secondary site is the only affected. In this case and if i remove the database in the secondary site, Is possible to obtain a DB replication from the primary site?
Do you recommend use a local data base in each Secondary Site or you recommend use only one?
In our organization we manage approximately 5000 endpoints.
Regards
