PENDING Deploying application using SCCM with input values
  • Thread starter Thread starter Markyb
  • Replies Replies 1
Markyb
Hi all,
I'm new to the packaging scene and have a question.
If I need to deploy an application and during the install, I need to input a server address, how do I get that into the package and deploy silently?
Mark
If the application supports a command line installation, check if you can also input server address so that the setup reads the values from command line and installs app silently.
For example, when you deploy adobe using sccm, command line install is
setup [--silent] [--ADOBEINSTALLDIR=] [--INSTALLLANGUAGE=]
In the above command you can specify adobe installation directory, installation language.
