PENDING Deploy OneDrive using SCCM
  • Thread starter Thread starter KyleASimpz
  • Replies Replies 4
  • Views Views 5K
KyleASimpz
Would anyone know the proper way to deploy Microsoft OneDrive via SCCM?
App vs Package
The proper setup instructions.
Ensure if Onedrive is creating a random Uninstall string (detection Method)?
For example, if you install any standalone MSI applications, the uninstall string never change - HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall but few cloud applications may randomly generate the Uninstall string. In this case, we should not use this registry hive in detection method (Applications Model).
Pl check if you can install the Onedrive application using PsExec. if it works and above case is true as well, then go for Packages Model(i.e., No detection method profile)
The onedrive.exe doesn't have a detection method attached to it so I set the detection method myself to a registry location below:
I did try the package method but it didn't properly install when I went to open it after installing it through software center.
Deploying it to "users" and not "computers" the better option?
TobiasKMdS
