SOLVED Deploy cmtrace tool using sccm
Ashish
Dear all,
I am seeking suggestion/guidance from someone who the experience of deploying "CMTrace" tool to all PCs in their environment. What is the best way to do that? I only want to drop it to a C:\ Windows so that the local IT support can go to this location and use the CMTrace to open log file.
Thanks in advance.
Regards
Ashish
Create a powershell script file (for example install.ps1) and paste the below script. Ensure CMTrace is in the same directory as the PowerShell script.
Command usage - powershell.exe -executionpolicy bypass -file install.ps1
Code:
 $RelativePath = (split-path $SCRIPT:MyInvocation.MyCommand.Path -parent)+"\"
$Architecture = Get-WmiObject -Class Win32_OperatingSystem | Select-Object OSArchitecture
$Architecture = $Global:Architecture.OSArchitecture
If ($Architecture -eq "32-bit") {
      Copy-Item -Path $RelativePath"CMTrace.exe" -Destination $env:ProgramFiles"\Windows NT\Accessories" -Force
      $Parameters = "Ftype logfile="+[char]34+$env:ProgramFiles+"\Windows NT\Accessories\CMTrace.exe"+[char]34+" %1"
      cmd.exe /c $Parameters
} else {
      Copy-Item -Path $RelativePath"CMTrace.exe" -Destination ${env:ProgramFiles(x86)}"\Windows NT\Accessories" -Force
      $Parameters = "FType logfile="+[char]34+${env:ProgramFiles(x86)}+"\Windows NT\Accessories\CMTrace.exe"+[char]34+" %1"
$Parameters = "assoc .log=logfile"
