SOLVED Deploy 2nd OS with TS
  • Thread starter Thread starter CAlden
  • Replies Replies 5
  • Views Views 791
CAlden
Hello everyone,
I am in urgent need of any help or advice.
I would like to distribute 2 OS (Win10) on a system with a TS via PXE. The normal TS runs perfectly with DomJoin etc.
After the first installation, a second OS should now be installed, but without DomJoin. Workgroup only. Driver updates etc. should also run here.
I hope someone can help me or give a tip on how to do this.
I'm really at the end of my Latin. :-) Thank you in advance.
Hy, yes Dual Boot. But is important to install with ts. After the Installation the User can choose the right os.
This is not a simple task. You will need to spend a lot of time on this. and I question the value of doing this.
Thank you for the answer. Do you have an instruction or a link for this? I‘m thankfull for any Tipps. Time is no Problem
This is an extremely rare request, so I doubt that you will find much on this subject.
