NEW Copy folder by SCCM Package Issue
  • Thread starter Thread starter tata789
  • Replies Replies 0
  • Views Views 4K
tata789
Hello
I need help to create command line batch file to move folder to User Desktop
I have folder in SCCM source location and in that folder have this 3 files
00000409
CmRcViewer.exe
RdpCoreSccm.dll
I create a SCCM Package and I create batch file to use for my command line and my command is
xcopy /E/Y/v Myservername\Software_folder\SCCM Remote\*.* C:\ Users\Public\Desktop\
when I deploy package it downloading fine but I get error Exit code 4, any help to fix my batch command line that will be good
for example
Script for Package:WMT00052, Program: Sccm 1802 Remote failed with exit code 4 execmgr 8/24/2018 12:27:46 PM 44836 (0xAF24)
MTC task with id {109B8BE8-5FDE-44E6-8D97-0228926992D2}, changed state from 4 to 5 execmgr 8/24/2018 12:27:46 PM 17284 (0x4384)
Raising event:
[SMS_CodePage(437), SMS_LocaleID(1033)]
instance of SoftDistProgramErrorEvent
AdvertisementId = "WMT200C9";
ClientID = "GUID:c0532d6e-f154-4e24-9575-b87e2556f199";
DateTime = "20180824162746.817000+000";
ExitCode = "4";
MachineName = "W-606976";
PackageName = "WMT00052";
ProcessID = 43812;
ProgramName = "Sccm 1802 Remote";
SiteCode = "WMT";
ThreadID = 44836;
UserContext = "NT AUTHORITY\\SYSTEM";
Raised Program Error Event for Ad:WMT200C9, Package:WMT00052, Program: Sccm 1802 Remote execmgr 8/24/2018 12:27:46 PM 44836 (0xAF24)
Execution is complete for program Sccm 1802 Remote. The exit code is 4, the execution status is FailureRetry execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
Requesting MTC to delete task with id: {109B8BE8-5FDE-44E6-8D97-0228926992D2} execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
MTC task with id: {109B8BE8-5FDE-44E6-8D97-0228926992D2} deleted successfully. execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="WMT00052",ProgramID="Sccm 1802 Remote", actionType 10l, value Result:FALSE, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
This execution request does not have a corresponding task in MTC. execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="WMT00052",ProgramID="Sccm 1802 Remote", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/24/2018 12:27:46 PM 32376 (0x7E78)
also if I can create package to c:\drive and shortcut on desktop for CmRcViewer.exe so user don't have to see all file in the folder
thank you
Arun
