PENDING Content location request for HMLxxxx failed. (Code 0x80040102)
  • Thread starter Thread starter Moegni
  • Replies Replies 10
Moegni
Hello everyone,
I am an sccm admin I am currently encountering a problem when I try to deploy a task sequence, indeed during deployment I have a content location request failed error for my client configuration manager client package.
Here are the actions i did :
-redistribute the package --> OSD NOK
-revalidate and redistribute the package --> OSD NOK
- I check my network everything is fine .
For your information i am using mecm 2303, windows ADK 10.1901 , windows 10 version 1809 and i use vwmware workstation 17.0.1
Attached the task sequence and the screenshot.
do you have an idea to solve this problem ?
  • smsts.log
    smsts.log
Try redistributing content again
Have you tested in on your test machines before deploying to the users ?
Hello everyone,
Are you only using IP Ranges? Exactly what error message are you getting in the logs?
hello, everyone
I use only one scop dhcp with an exclusion
I made a new package and distributed it but the error carried over to the boot image now.
I don't why because the right on the share and the network are fine
Exactly what error are you getting? What troubleshooting have you done?
Hello, Sir
My lab is set up as follows:
-MECM 2303
-An AD/DHCP server (Windows Server 2016),
-SQL 2017 with the latest CU,
-SQL Management 19.1,
-Windows ADK 10.19041,
-Windows 10 1809.
-workstation vmware 17 pro
- I have one DHCP scope and one boundaries on SCCM
I am currently encountering a problem when I try to deploy a task sequence, indeed during deployment I have a content location request failed error for my boot image
  • re-import the boot image
  • redistribute the boot image
  • revalidate the boot image
  • check my network and my boundaries --> OK
  • check the acces rights on the folders --> OK
There is my SMSTSLOG on attach files
NickCarter
