PENDING Configuration Manager 2403 and Co-Management
  • Thread starter Thread starter nkerr
  • Replies Replies 13
  • Views Views 4K
nkerr
Active Member
Co-management works on the server. However, it does not work if you run the manager from a PC. You get the following error message:
Co-management
Missing Console Extension
This feature required the Configuration Manager console extenstion for Microsoft Edge Webview2 Runtime. Install Webview2 console extension then reopen the console.
Check if there are any extensions pending installation under Administration\Overview\Updates and Servicing\Console Extensions, and cross-check with server settings
The ConfigMgr console will require Microsoft Edge Webview2 Runtime extensions. You'll have to install it for the console to work. Follow the suggestion provided by @MJ-Tech
When I click on Console Extensions, I get the message that Configuration Manager can't connect to the administration service.
There is no certificate on the SMS Provider site system server. Make sure it has a valid PKI or Configuration Manager-generated certificate for the site.
Under Administration > Overview > Site Configuration > Sites > Properties, ensure that you have selected the correct site system settings options. For more information, please refer to this https://www.prajwaldesai.com/enable-sccm-enhanced-http-configuration/
Also make sure – SMS Issuing certificate is not BLOCKED and not expired - Administration\Overview\Security\Certificates
SMS Issuing certificate has an expiration date of 7/6/2025 and the status is unblocked.
I downloaded and installed the Microsoft Edge Webview2 Runtime extensions on my PC. It did not make an difference with the configuration manager console on my PC.
SMS Issuing certificate has an expiration date pf 7/6/2025 and the status is unblocked.
I do not see the SMS Role SSL Certificate
The SMS Role SSL Certificate enhanced HTTP certificate is issued by the root SMS Issuing certificate. I think there is some issue with your certificate authority.
When I view the properties for the site, under Trusted root certification Authorities it says None specified.
dtsfan
