SOLVED CMG Provisioning errors
  • Thread starter Thread starter youssaid
  • Replies Replies 1
  • Views Views 7K
youssaid
Hello everyone,
I installed a new CMG but I keep getting the following errors from the log file,
Failed to get cloud service <CMG Name> network out metrics with status code NotFound. Check [Monitor/Activity log] on Azure Portal for more information
Hyak.Common.CloudException: Failed to get cloud service network out metrics~~ à Microsoft.ConfigurationManager.AzureManagement.ResourceManager.GetCloudServiceMetricsNetworkOut(String resourceGroupName, String cloudServiceName, String deploymentSlot, String webRoleName, DateTime startTime, DateTime endTime)~~ à Microsoft.ConfigurationManager.CloudServicesManager.AnalyticsCollectionTask.Start(Object taskState).
Service <CMG Name> has failed. Exception Hyak.Common.CloudException, Failed to get cloud service network out metrics.
I have registered the Microsoft.CalssicCompute resource
I checked the Date/Time sync
I created a storage account with the same name
I can see the CMG on the azure portal but on sccm server it is not registered,
can you please help me,
Regards,
Make sure that your account has the ability to create Azure storage in your Azure subscription
