PENDING CM Agent Won't Install - BITS Issue?
  • Thread starter Thread starter George3113
George3113
I have a Windows 10 PC that won't install the config manager agent. One of the errors implies the version of BITS is the cause of the error. Anyone have any ideas what would cause this?
Any help is appreciated.
Thanks.
Failed to get client version for sending state messages. Error 0x8004100e ccmsetup 7/11/2022 8:29:22 AM 5856 (0x16E0)
Params to send '5.0.8412.1004 Deployment Error: 0x0, ' ccmsetup 7/11/2022 8:29:22 AM 5856 (0x16E0)
A Fallback Status Point has not been specified and no client was installed. Message with STATEID='100' will not be sent. ccmsetup 7/11/2022 8:29:22 AM 5856 (0x16E0)
Failed to send status 100. Error (87D00215) ccmsetup 7/11/2022 8:29:22 AM 5856 (0x16E0)
CreateInstance of CLSID_BackgroundCopyManager failed with 80080005. Unable to check BITS version ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
This operating system does not contain the correct version of BITS. BITS 2.5 or later is required. ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
Failed to get client version for sending state messages. Error 0x8004100e ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
Params to send '5.0.8412.1004 Deployment This operating system does not contain the correct version of BITS. BITS 2.5 or later is required.' ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
A Fallback Status Point has not been specified and no client was installed. Message with STATEID='321' will not be sent. ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
Failed to send status 321. Error (87D00215) ccmsetup 7/11/2022 8:33:51 AM 5856 (0x16E0)
Failed to connect to policy namespace. Error 0x8004100e ccmsetup 7/11/2022 8:33:51 AM 10292 (0x2834)
Failed to revoke client upgrade local policy. Error 0x8004100e ccmsetup 7/11/2022 8:33:51 AM 10292 (0x2834)
CcmSetup failed with error code 0x80080005 ccmsetup 7/11/2022 8:33:51 AM 10292 (0x2834)
I tried the install with /BITPriority:LOW , same result. Log below.
BITS is running.
If you have any other ideas, please let me know.
Thanks.
==========[ ccmsetup started in process 21848 ]========== ccmsetup 7/13/2022 9:08:27 AM 50192 (0xC410)
Updated security on object C:\windows\ccmsetup\cache\. ccmsetup 7/13/2022 9:08:27 AM 50192 (0xC410)
Launch from folder C:\windows\ccmsetup\ ccmsetup 7/13/2022 9:08:27 AM 50192 (0xC410)
CcmSetup version: 5.0.8412.1004 ccmsetup 7/13/2022 9:08:27 AM 50192 (0xC410)
Folder 'Microsoft\Microsoft\Configuration Manager' not found. Task does not exist. ccmsetup 7/13/2022 9:08:27 AM 50192 (0xC410)
In ServiceMain ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Successfully started the ccmsetup service ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
Folder 'Microsoft\Microsoft\Configuration Manager' not found. Task does not exist. ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Failed to connect to policy namespace. Error 0x8004100e ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
Failed to revoke client upgrade local policy. Error 0x8004100e ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
Deleted file C:\windows\ccmsetup\ccmsetup.exe.download ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
Folder 'Microsoft\Configuration Manager' not found. Task does not exist. ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
CcmSetup is exiting with return code 0 ccmsetup 7/13/2022 9:08:27 AM 26772 (0x6894)
[DOCXDH0Y6CP2] Running on 'Microsoft Windows 10 Pro for Workstations' (10.0.18362). Service Pack (0.0). SuiteMask = 272. Product Type = 18 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Ccmsetup command line: "C:\windows\ccmsetup\ccmsetup.exe" /runservice "SMSSITECODE=Our-SiteCode" "/mp:Our-Server" "/retry:1" "/BITSPriority:LOW" "CCMLOGMAXSIZE=1000000" "CCMLOGMAXHISTORY=0" ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Command line parameters for ccmsetup have been specified. No registry lookup for command line parameters is required. ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Command line: "C:\windows\ccmsetup\ccmsetup.exe" /runservice "SMSSITECODE=Our-SiteCode" "/mp:Our-Server" "/retry:1" "/BITSPriority:LOW" "CCMLOGMAXSIZE=1000000" "CCMLOGMAXHISTORY=0" ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
SslState value: 224 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
CCMHTTPPORT: 80 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
CCMHTTPSPORT: 443 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
CCMHTTPSSTATE: 224 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
CCMHTTPSCERTNAME: ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
FSP: ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
CCMFIRSTCERT: 1 ccmsetup 7/13/2022 9:08:27 AM 11072 (0x2B40)
Config file: ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Retry time: 1 minute(s) ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
MSI log file: C:\windows\ccmsetup\Logs\client.msi.log ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
MSI properties: SMSSITECODE="Our-SiteCode" CCMLOGMAXSIZE="1000000" CCMLOGMAXHISTORY="0" CCMHTTPPORT="80" CCMHTTPSPORT="443" CCMHTTPSSTATE="224" CCMFIRSTCERT="1" ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Source List: ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
MPs: ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Our-Server ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
MapNLMCostDataToCCMCost() returning Cost 0x1 ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
No version of the client is currently detected. ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Folder 'Microsoft\Configuration Manager' not found. Task does not exist. ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Updated security on object C:\windows\ccmsetup\. ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Failed to get client version for sending state messages. Error 0x8004100e ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Params to send '5.0.8412.1004 Deployment Error: 0x0, ' ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
A Fallback Status Point has not been specified and no client was installed. Message with STATEID='100' will not be sent. ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
Failed to send status 100. Error (87D00215) ccmsetup 7/13/2022 9:08:28 AM 11072 (0x2B40)
CreateInstance of CLSID_BackgroundCopyManager failed with 80080005. Unable to check BITS version ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
This operating system does not contain the correct version of BITS. BITS 2.5 or later is required. ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
Failed to get client version for sending state messages. Error 0x8004100e ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
Params to send '5.0.8412.1004 Deployment This operating system does not contain the correct version of BITS. BITS 2.5 or later is required.' ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
A Fallback Status Point has not been specified and no client was installed. Message with STATEID='321' will not be sent. ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
Failed to send status 321. Error (87D00215) ccmsetup 7/13/2022 9:12:32 AM 11072 (0x2B40)
Failed to connect to policy namespace. Error 0x8004100e ccmsetup 7/13/2022 9:12:32 AM 50192 (0xC410)
Failed to revoke client upgrade local policy. Error 0x8004100e ccmsetup 7/13/2022 9:12:32 AM 50192 (0xC410)
CcmSetup failed with error code 0x80080005 ccmsetup 7/13/2022 9:12:32 AM 50192 (0xC410)
