SOLVED Clients not showing and MCS errors
James Young
I recently found your site and have found it very useful. Thank you for sharing this information. Your info on the PKI certs was especially helpful.
I am using SCCM2016 (1606) on Server 2016
I have been able to successfully push the client install (according to the clients anyway, their logs state it done), but they are not showing up in SCCM.
I also have following errors on the Server:
- MP Control Manager detected DMP is not responding to HTTP requests. The http status code and text is 404, Not Found.
- MP Control Manager detected management point is not responding to HTTP requests. The HTTP status code and text is 404, Not Found.
- MCS Control Manager detected MCS is not responding to HTTP requests. The http error is 404.
I also get the following though the service is started and running with proper credentials: Notification Server on myserver.domain.local.org failed to initialize. The operating system reported error 2147942405: Access is denied. (changed the actual name)
I have gone into IIS and ensured every application runs with the admin account I use. SQL server is on another server, though I noticed the SCCM server still installed sql express instance.
Is there any assistance you can provide, also, what other information can I give you to help?
Thank you
Sailaja
