mmedrano19870406 New Member Messages 2 Reaction score 0 Points 1 Aug 1, 2019 #1 I need to deploy an application in .exe that has the option to install the client and server software by sccm Attachments error sccm.JPG 21.9 KB · Views: 7
Edy Well-Known Member Messages 310 Solutions 3 Reaction score 33 Points 28 Aug 1, 2019 #2 you need to check with the vendor what are the supported parameters and then you can use a batch script to install Upvote 0 Downvote
Prajwal Desai Forum Owner Staff member Messages 4,982 Solutions 143 Reaction score 969 Points 413 Aug 2, 2019 #3 That's correct. Go to the Software vendor site and check if there is way to install the both client and server components. Upvote 0 Downvote
