PENDING 1906 to 1910 Update stuck after setting up HTTPS-enabled management point
  • Thread starter Thread starter Nate
  • Replies Replies 1
Nate
I was successful in updating to 1910. I then wanted to turn on bitlocker management but could not because I was not set up as HTTPS-enabled.
I followed a guide in order to do this and was not successful. I had broken my image process and needed to get that back up and running again so I reverted to the image of 1906. With that done, I followed another guide and figured out were I had made a mistake last attempt at making SCCM HTTPS-enabled.
Now that that's in place, I am attempting to upgrade to 1910 again, and keep getting errors. Fails to move and delete files.
I've seen that this could be a permissions error. I've given IUSR rights to the folders involved.
I've also seen that this could be a DP issue. Each time I attempt to restart the process I run a CMUpdateReset and and this last time I run a ContentLibraryCleanup.
I'm not sure what to try next or if I have permission correct now that it's running on HTTPS.
rbushart
