SOLVED WDS EFI Boot stuck on Waiting for Approval
  • Thread starter Thread starter wikusg
  • Views Views 4K
wikusg
Good day
I've been struggling for 2 weeks now and am about to give up. BIOS boot works 100% EFI gets stuck at waiting for approval. Newest version of Endpoint Configuration manager. I've taken the exact same servers (SCCM, DC, DHCP and a test client) and cloned them to a virtual lab. In the lab the config works 100% for both BIOS and EFI. Everything runs on VMWare hosts. I've tried adjusting block size, recreated the RemoteInstall share, uninstall re-install PXE on the DP, removed and re-installed WDS. I've even replaced the physical switch where the host link to( this should however not affect the process as everything is on the same host on the same vSwitch)
Any advice on what else I can do to troubleshoot the issue?
Wikus
mattjimf
