SOLVED Usagedata.cab does not contain Telemetry data
  • Thread starter Thread starter memihir
  • Replies Replies 1
  • Views Views 10K
memihir
Hi Guys,
I am trying to update SCCM offline. From version 1602 to 1702.
When using prepare with ServiceConnectionTool it works fine and creates cab file but when I try to use connect it gives following warning and error message before terminating.
Warning in the log file is Usagedata.cab signature could not be verified and Error says failed with status code Error and error code Unknown error. Usagedata.cab does not contain Telemetry data.
I tried quite a few articles on net but no answer found, any help with this would be appreciated.
I had a similar problem when updating from 1702. turns out it was the command that was messed up
this is what i was running:
ServiceConnectionTool.exe -connect -usagedatasrc c:\temp\UsageData\usagedata.cab -updatepackdest C:\temp\UpdatePacks
the problem was that service connection tool didn't want the actual .cab file name, just wanted the directory
This command worked:
ServiceConnectionTool.exe -connect -usagedatasrc c:\temp\UsageData -updatepackdest C:\temp\UpdatePacks
Saikamma
