SOLVED Upgrade SCCM 2010 Issue
yaakoubi
I ran Precheck and everything is fine, but in the Validate Redistributable Files phase, I have the error below :
Manifest version 202010 does not match 202103
Failed to verify redist file for update D:\Microsoft Configuration Manager\CMUStaging\6B4F84B7-5555-48B0-AECC-74FB5A8AA24B\redist\ConfigMgr.Manifest.cab
Any idea!
Solution:
  1. Take backup of both the files and both can be found in following location: Drive:\Program Files\Microsoft Configuration Manager\bin\X64: Manifest.xml and cmupdate.exe
  2. Kindly navigate to Drive:\Program Files\Microsoft Configuration Manager\ EasySetupPayload \ GUID \SMSSETUP\BIN\X64. Find the Cmupdate.exe, copy it and paste it in Drive:\Program Files\Microsoft Configuration Manager\bin\X64, delete the previous Cmupdate.exe.
Yes I did but it's the same, I think the problem is in the Manifest.xml and cmupdate.exe contain version 202103 and need to install 20202010:
Solution:
lynnc
