SOLVED Unmatched exit code (1) is considered an execution failure
JAYJ
Command line: Powershell.exe -ExecutionPolicy Bypass -file "BackupAgent_Install.ps1"
Same script works fine manually on PC. However if i execute via SCCM, it throws an error. Installation is not successful.
Kindly advise to resolve this.
Error: AppEnforce log
Process 10964 terminated with exitcode: 1
Without seeing the script can only say that either there's an uncaught throw or an intentional exit returning 1. Can you attach the script?
Thank you Sam for your response.
However i noticed, it is application behavior. If SCCM executes the script, application exe unable to download the patches from internet. If i execute the same script manually, it downloads the hot fix patches from internet. This i noticed from application(.exe) created log files.
Apologize for the trouble.
Jay
Thank you Everyone. Since above error related to application behavior, i am closing this ticket.
Jelsantos
