SOLVED SCCM HA configuration with SQL 2019 STD.
  • Thread starter Thread starter Rohit
  • Replies Replies 6
  • Views Views 4K
Rohit
Active Member
Hello All,
I have installed MECM 2006 primary site server with SQL 2019 std version on the same server. My client wants to configure HA for MECM. Is it possible to configure HA with SQL std 2019 and SQL and Primary site server on the same server ??? Please suggest.
Thanks,
Rohit
Thanks, Youssef for providing the URL it was helpful. You can mark this thread as resolved.
Rohit
If you are planing to configure a Always On Availability Group, you must have Enterprise edition.
Others HA supported scenarios are described in the following official doc:
Hi Youssef, Not related to SCCM. It is about WFCS. What will happen if the domian admin account used to create a WFCS for SQL Server Always on is deleted. Will if affect the cluster operation? Should we create a separate Cluster Admin account ? Please reply
TobiasKMdS
