SCCM BGBserver log errors - help
Lewis.Burrell
Hi there,
We are getting a lot of errors in the log BGBserver.log
ERROR: Authentication failed - closing the connection. Exception: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> System.ComponentModel.Win32Exception: The Local Security Authority cannot be contacted~~
In addition there are other errors in this log such as
ERROR: Expecting more data from client (IPaddress)
Any help in getting these errors deciphered would be greatly appreciated and the meaning to them so if changes need to be made then they can be changed.
I too would love an answer to this as my BGBserver.log is awash with red and this exact error message.
ERROR: Authentication failed - closing the connection. Exception: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> System.ComponentModel.Win32Exception: The client and server cannot communicate, because they do not possess a common algorithm~~ --- End of inner exception stack trace ---~~ at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception)~~ at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)~~ at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)~~ at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)~~ at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest, Boolean renegotiation)~~ at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)~~ at Microsoft.ConfigurationManager.BgbServerChannel.BgbTcpListener.ProcessClient(Object state) InnerException: The client and server cannot communicate, because they do not possess a common algorithm SMS_NOTIFICATION_SERVER 5/29/2024 8:40:15 AM 14992 (0x3A90)
HI All,
I am also observed same issue now its fixed in my infra.
Issue : All the machines are reported as Offline.
Fix: ( Mapping the correct certificate got resolved the issue for me)
While checking the logs observed expired server certificate precent in certificate store. But in SQL manager and the registry its mapped the updated certificate. I have deleted the Expired certificate and restarted the Sms_executive service.
NickCarter
