SOLVED SCCM 2012 Reporting Not Working
  • Thread starter Thread starter namerg
  • Replies Replies 7
  • Views Views 21K
namerg
I am testing SCCM 2012 but somehow I am not able to load reports fine.
SSRS is installed and working but not the sccm reports ?
Thoughts ?
I am uploading some screenshots when i double click on the "Administrative activity log." report.
I get this also:
An error has occurred during report processing. (rsProcessingAborted)
Cannot impersonate user for data source 'AutoGen__5C6358F2_4BB6_4a
1b_A16E_8D96795D8602_'. (rsErrorImpersonatingUser)
Log on failed. (rsLogonFailed)
The user name or password is incorrect. (Exception from HRESULT: 0x8007052E)
I do not see the Folder Settings icon on IE when I open the Reports Manager
Thanks for your help,
I guess the issue with the user account that you are trying to access the reports. Check if its valid (not locked).
Correct Prajwal. I do not understand why. I used a domain admin account to install sccm and sql, then i created a non domain admin account and gave full administrator right inside sccm. Eveything works fine except presenting data via ssrs. I am able to query data with both accounts inside SQL mgmt console. All is good. But not able to present data via reports.
Does it works fine with a domain account ?.
Prajwal, both accounts work fine inside SQL Mgtm Console.
Almost got it. Once i checked mark "Impersonate the authenticated user after a connection has been made to the data source" then i was able to run any reports. But, somehow the option "Impersonate the authenticated user after a connection has been made to the data source" does not remain checked mark. See screenshots/attachments.
So, how do i make the setting "Impersonate the authenticated user after a connection has been made to the data source" to be checked mark for good ?
SQL Server Analysis Services only supports Windows account credentials. Therefore select both options "Use as Windows credentials when connecting to the data source" and "Impersonate the authenticated user after a connection has been made to the data source" for an Analysis Services data source.
Hope this will work for sure :)
Problem was with domain account as per Prjawal said..
Please check either you are an SSAS admin or not . If not , get the access and be SSAS Admin..
skanaguk
