SOLVED Past due - will be installed explained
  • Thread starter Thread starter avi_ei
  • Replies Replies 21
  • Views Views 73K
avi_ei
Active Member
Hi all,
I'll appreciate an explanation about "Past due - will be installed" message on application deploy in software centre and how i can initiate an installation of an application with that status or fixing it - I don't want the user to press and make a manual install.
The application is required and distributed to a user collection.
As i understand on the SCCM console those clients with that status (Past due - will be ...) will show in "In Progress" that as "Content Downloaded"
TNX
Well,
Since it was happening on 10 workstations only I've tried to uninstall manually from a remote workstation using powershell.
After the manual uninstall of the superseded application the deployment ran OK and installed the required app.
Still even there is no issue anymore the reason for the problem is not understandable.
Thank you for all your help
I have a maintenance window, a deadline and repeatidly machines do not install either during the maintenance window (which is 5 hours long) or during the day (the install during deadline period). I believe the maintenance window of 5 hours is continuously not long enough. SCCM may not fire off the update task until hour 4, calculate the 1 hour remaining is not enough and not install. I believe the reason the deadline install (anytime basically) does not work is because my business hours on the default windows setting is set to 5 am - 10 pm. It will never install no matter what SCCM wants. So from 5 am to 10 pm no install. The maintenance window in my case starts at midnight and goes till 5 a.m. and doesn't install because for whatever reason it decides there is not enoug time.
I just took a machine and adjusted by windows business time by unchecking s, m, t, w, th, f, s boxes. I also set the time to 8 pm - 9 pm (only one hour). Although the time doesn't matter because I unchecked the days of the week (but we are all superstitous right?). I restarted the sms agent host service on the client. Now the logs: 1) updates deployment show a need for patches; 2) WUAHandler shows "Async installation of updates started".
I do not see the software center beginning patches, I have only waited a few minutes during the deadline period. However as soon as I restarted the service (I cleared ccmcache earlier) I immediately saw patches download to the folder.
I manually started patches on this machine and it is patching.
This doesnt prove a resolution (other that the logs suggesting it). But I have gone around and around and around with patches not deploying. I have never turned off the business time on the windows machine. I think this setup on the machine is useless for most people.
Summary: if you are confident on the deployment package, the maintenance window, see "not enough time for maintenance window or no maintenance window found then: 1) turn off the business time; 2) shorten it and increase your maintenance window to have alot more time to run (although that will initiate a reboot huh?
I am going to verify the business window as the culprit and probably push out a GPO to turn it off on all machines. I will use the maintenance window basically to stop my deadline behaviour from rebooting the machines during work hours.
Just added a server that was not in a maintenance window. Before I did a machine poliy checkin and updates deployment checkin I 1) flushed the ccmcache; 2) unchecked sun - sat active hours manually in the software center "options". I ran the two client actions and patches were downloaded and immediately began installing.
Definately the business hours/active hours that is blocking the deadline installation of packages. I am following a few threads on how to turn this off.
Blackcee
