SOLVED No SRS Reports showing up in SCCM console
Manuel
Hi
when I open Reporting\reports
I just seeing no ítems found
I tried with also every step mentioned by INFORMATION found on wWW with no result at all
any recomentation would it be appreciated
thanks in advaced
Manuel
Yes it is, and it is also running.
Reports are shown everytime I use the user account used to fully deploy SCCM stand alone server, this is the first user account that has Full Administrator role.
After it, I decided to add a new user account and get all report working but it can be instead I get none reports showing up.
Hi Manuel,
What is the error message you are getting while opening a report through browser ?
good log to check is ReportServerService_<timestamp>.log. It logs all errors and it will provide a complete call stack
Maunil, I found no error there.
I have fix it doing the following steps:
1st change I did:
In the path
C:\Program Files\Microsoft SQL Server\MSRS11.MSSQLSERVER\Reporting Services\ReportServer
Modicar el archive
rsreportserver.config
I found SecureConnectionLevel
<InstallationID>{26673d61-18a3-4427-aed3-f7abade2159e}</InstallationID>
<Add Key="SecureConnectionLevel" Value="0"/>
I change value from 2 to 0 and I have remove https from cm console
2nd change I did:
In the path
I edit this file:
I Go to
<Authentication>
<AuthenticationTypes>
<!--<RSWindowsNegotiate/>-->
I commented RSWINDOWSNEGOTIATE with <!
and restart Reproting Services and it Works
Now, I can access from my remote administration console of SCCM to SCCM site server and see all reports in reports node
