SOLVED Management point showing critical and size showing 0 Bytes
  • Thread starter Thread starter Rohit
  • Views Views 13K
Rohit
Active Member
Hello all,
I hve installed MP on remote server. Mp installed properly to verify checked mpmsi and mpsetup log files.
When I goes to site status under monitoring section mp shows critical and size showing 0 bytes. Because of this clients not communicating with mp.
Anyone has idea that how to resolve this ??
Are you sure if the MP role is installed without any errors ?. Can you upload - mpMSI.log, mpSetup.log.
Hello Prajwal , thanks for your reply.
issue has been resolved now. Actually there was no error in mpmsi and mpsetup.log files in which installation was successful with 0 return code.
I found error in mpcontrol.log file in which i found that http test getting failed then checked ports 135,445 was blocked. After port opening issue resolved now critical error is gone and size also reflecting in console and now clients starts communicating with mp.
Thanks !
junaidqader
