SOLVED How we can remove Symantec registry key values
  • Thread starter Thread starter vin418
  • Replies Replies 4
vin418
Active Member
Hi All,
There is Symantec encryption registry key value still available in legacy section in registry, however i was able to delete other registry key values manually but not the legacy one, is there any way we can remove those or is there any tool that we can use to remove the same.
There are many ways remove a reg key, to do this, vbs, powershell, reg.exe etc.
Hi Garth,
If there is any script can you share the same, so that we can remove the complete registry key or symantec.
A quick google search will show you a ton of scripts to remove a regkey. There are no tricks to this.
use configuration item and configuration baseline to detect and remove the key.
lynnc
