SOLVED Failed to copy smsdp.dll Distribution Point errors
  • Thread starter Thread starter nbdamman
  • Replies Replies 8
  • Views Views 7K
nbdamman
After upgrading to SCCM 2002 I am not getting an error stating that Distribution Manager failed to install distribution point. Looking into the distmgr log I see the error - Failed to copy smsdp.dll from Primary location to the same SMS_DP$ on the DP. I've tried removing the DP role and re-adding it with the same results.
Any help would be greatly appreciated.
Appreciate for sharing the logs.
Failed to copy E:\Program Files\Microsoft Configuration Manager\bin\x64\\smsdp.dll to \\LFGSCCMDP1.LIBBEY.LOCAL\SMS_DP$\sms\bin\\smsdp.dll. Error - 64
This means unable to extract the smsdp.dll file from your sccm server to New DP. It could be due to permission issue at your DP or sccm due to AV. Try to manully copy smsdp.dll file and initiate installation.
Ok, I manually copied the dll over to the DP, tried to redistribute the package and looks like the error is the same. Trying to copy the dll over to the DP fails.
Do you think I need to remove and reassign the DP role to those DPs?
check what the monitoring tab says
Monitoring || distribution status||distribution point configuration status||select the dp ||details
dimasyandr
