SOLVED ERROR : The Specified path does not contain a valid operating system
  • Thread starter Thread starter Azeem
  • Replies Replies 4
  • Views Views 10K
Azeem
i am using CM with 1906 with hotfix KB4517869, and planning to upgrade windows 7 to windows 10 1909, getting this error while adding "install.wim" file in "Operating system Upgrade Packages" tab.
ERROR
"The Specified path does not contain a valid operating system or you do not have permission to access it. Specify a valid path.
i got ISO file from MS volume Licensing service center..
not sure what i am missing. Help Please.
Check the security & share permissions in the OSDeploment folder.
If there are Ok, try to download 1903 ISO and import it in SCCM, let us know for the result.
Thank you for reply Youssef. i double checked Permissions on OSDeploment folder, seems fine, i am able to add windows 10 1909 image from same shared location when i am adding under "Operating system Images" but when i am trying to add same image from same shared location under "Operating System Upgrade Packages" then i am getting this Error.
i have feeling i may need other images which is just for upgrade previous windows 7 version, maybe this install.wim file is for fresh installation, but i don't know where you find that image i tried VLSC and MSDN .
i tried 1903 images as well.
My Mistake, i just copied install.wim (5.windows 10 Pro) file in shared folder. after coping all extracted image i have no issue now.
junaidqader
